GFCI Starboard side
Flagmanmike
GFCI Starboard side
Post by Flagmanmike »
The onboard AC power was working just fine then all the outlets on the port side had no power at the same time. There is a FGCI on the starboard side in the forward berth. Is there a GFCI for the port side, if so, where? 2005, Hull 314. Thanks, Mike Cronin
Re: GFCI Starboard side
Mike, the port side GFCI outlet is in the head. It's just above and to the left of the door under the sink.
Pbrenner
Post by Pbrenner »
Good trick it took us some time last year to figure it out ;-)
Thanks Ken !!
