GFCI Starboard side
Flagmanmike
GFCI Starboard side
The onboard AC power was working just fine then all the outlets on the port side had no power at the same time. There is a FGCI on the starboard side in the forward berth. Is there a GFCI for the port side, if so, where? 2005, Hull 314. Thanks, Mike Cronin
Re: GFCI Starboard side
Mike, the port side GFCI outlet is in the head. It's just above and to the left of the door under the sink.
Pbrenner
Good trick it took us some time last year to figure it out
Thanks Ken !!
Thanks Ken !!
Happily sailing on "fuzion III" (Hull 452) in Québec, Canada
