Hi all. Quick question. Has anyone replaced the hose (2" diam) from the water muffler to the seacock? If so how many feet does it take? I am guessing around 10-12 feet???
thanks
Exhaust Hose length
seatime2
Re: Exhaust Hose length
Hi Dave,
I had mine done last year and the service engineer ordered a 3 metre length which worked out fine.
Cheers, Richard
Nancy Scott #439
Cheers, Richard
Nancy Scott #439
Monty
I bought 13' of Shields 250 Series ShieldsFlex II with wire from Go2Marine 2 years ago. Had enough to trim the edges and maybe a few inches extra. This also covered from the motor to the muffler. Make sure you put the big turn in the hose before it exhausts out the hull. I laid it out in the sun for a little while to loosen it up. Wasn't the worse exhaust hose replacement I did; at least you can get to it reasonably well. Steve
Steve Montgomery
Salty, hull #418
Deltaville, VA
Salty, hull #418
Deltaville, VA
Perfect. THANKS. Yeah, I look at that bend and it scares me...
I just replaced from muffler to hull and the old hose was 8ft 8" and I replaced it with 9ft.
sjones12121994
Yes, I’ve replaced that hose before. It usually takes around 10-12 feet, depending on your boat's setup. To be sure, I'd recommend measuring the old hose or running a tape measure along the path where the new hose will go. A professional plumber can also help on replacing that hose for you.
Haro
- Contact:
Remove your existing hose, lay it flat and measure it.
1999 C36 MKII, M35B http://mei1970.org/saillavie Coyote Point Marina
