Exhaust Hose length
Exhaust Hose length
Hi all. Quick question. Has anyone replaced the hose (2" diam) from the water muffler to the seacock? If so how many feet does it take? I am guessing around 10-12 feet???
seatime2
Re: Exhaust Hose length
Post by seatime2 »
Hi Dave,
I had mine done last year and the service engineer ordered a 3 metre length which worked out fine.
Cheers, Richard
Nancy Scott #439
Monty
Post by Monty »
I bought 13' of Shields 250 Series ShieldsFlex II with wire from Go2Marine 2 years ago. Had enough to trim the edges and maybe a few inches extra. This also covered from the motor to the muffler. Make sure you put the big turn in the hose before it exhausts out the hull. I laid it out in the sun for a little while to loosen it up. Wasn't the worse exhaust hose replacement I did; at least you can get to it reasonably well. Steve
Steve Montgomery
Salty, hull #418
Deltaville, VA
Perfect. THANKS. Yeah, I look at that bend and it scares me...
Post by cuthbert »
I just replaced from muffler to hull and the old hose was 8ft 8" and I replaced it with 9ft.
sjones12121994
Post by sjones12121994 »
Yes, I’ve replaced that hose before. It usually takes around 10-12 feet, depending on your boat's setup. To be sure, I'd recommend measuring the old hose or running a tape measure along the path where the new hose will go. A professional plumber can also help on replacing that hose for you.
Haro
Contact:
Post by Haro »
Remove your existing hose, lay it flat and measure it.
1999 C36 MKII, M35B http://mei1970.org/saillavie Coyote Point Marina
