I'm talking about the one under the galley sink that's attached to the Shurflo pump. The one I have is an inline, which is a pain to clean. I want to put in the bowl type that can easily have the screen removed for cleaning. I need the part number of it, if anyone's replaced it.
Has anyone changed the filter screen on the fresh water pump
Ed Kruzel
S/V Emily
Hull #399, 2006 C350
Cataumet, MA
S/V Emily
Cataumet, MA
Re: Has anyone changed the filter screen on the fresh water
You are talking about catching any debris that is coming from your water tanks .... I'd say that once you get the initial debris out from the installation at the factory (drilling holes) you shouldn't have anything else in there. After the inital cleaning, I would think it would remain clean. ?
TRIUMPH
TRIUMPH
Ideally, you're correct. But I've seen some weird stuff come out of "fresh" water dock hoses.Triumph wrote:You are talking about catching any debris that is coming from your water tanks .... I'd say that once you get the initial debris out from the installation at the factory (drilling holes) you shouldn't have anything else in there. After the inital cleaning, I would think it would remain clean. ?
TRIUMPH
Ed Kruzel
S/V Emily
Cataumet, MA
S/V Emily
Cataumet, MA
Ed, is this what you are asking about? It is the fresh water filter inline under the fresh water pump. It is all located under the galley sink. Hopefully, the photo will help you find the part number. We have a Shur Flo, Aqua King, Product #: 3901-0206 or 3901-0216
- IMG_0147.JPG (33.98 KiB) Viewed 8490 times
