Hey,
In the process of unwinterizing, I cracked one of the fittings that attach to the water distribution manifold. Does anyone know where I can find those parts? They are hose barb into the red tubing and a seal with threaded female fitting on the other side.
*headslap*
J.
Replacement fittings for water distribution manifolds
- bibbjs
J. Bibb
Magick Dragon (formerly Snooze Time)
Hull #45
Hull #45
Re: Replacement fittings for water distribution manifolds
As a temp fix to get you going, the threads are standard plumbing size. I made my bypass with brass fittings from the Home Depot. Not sure who makes the manifolds and connectors. The might be from Whale Marine.
