Can anyone tell me whether the threads on the temperature sending unit for a Westerbeke M35B are metric or NPT? I'm sitting 6 hours away from my boat and would like to order a replacement sender before I head back. I'm hoping to use a generic sender (with the same temp range) rather than the more expensive factory brand if possible.
All of this is part of a long process of troubleshooting a water temp gauge that acts normal until engine rpm's hit 2000-2100 then starts instantly jumping to the right side of the gauge. In the meantime motor appears to be running within normal temp range, pumping lots of sea water (no steam), no heat "smell", and no high temperature alarm.
I've seen various references to the same issue on several internet sites. The odd thing is that the experienced opinions have all suggested different fixes. Thanks for any input. captain dan
M35B water temperature sender threads
Re: M35B water temperature sender threads
Dan,
I suspect you can get the proper temperature sensor from many auto parts store that sells Kubota parts. Another thread on this forum seemed to indicate that the M-35B is a Kubota block engine. You may want to read this thread for details http://www.catalina350.net/phpBB3/viewt ... bota#p2987
Richard Ad
Before you replace the sender try cleaning the wires at the back of the gauge and the bus behind the instrument cluster. Remove one at a time, clean with sand paper and replace, then clean the next one. It worked for mine.
Capt. Nini
I had what sounds like, a similar problem, that was solved by changing the coolant.
Coolant was old and lost its effectiveness. Be sure to use RED coolant.
Hope this helps
Hope this helps
