Companionway hatch board lock
Dave DeSalvo
I just broke a key off in my companionway lock top board. Can anyone recommend a lock to replace it. My 2006, Hull number 383, came with 2 keys and after searching high and low for additional key blanks have been told they are not available. Now I an down to one key and a busted lock. Can anyone help. Thanks.
Re: Companionway hatch board lock
Dave,Dave DeSalvo wrote:I just broke a key off in my companionway lock top board. Can anyone recommend a lock to replace it. My 2006, Hull number 383, came with 2 keys and after searching high and low for additional key blanks have been told they are not available. Now I an down to one key and a busted lock. Can anyone help. Thanks.
I ordered blanks from Catalina in Fl.
Took them to Home Depot and they made copies.
Leigh Weiss c-350 #155
I went to a lock smith and found a blank. An italian key with the initials CAS.
Hope that helps
Hope that helps
jbd3
Can you provide any info on the blank you found to fit? I have had no luck trying to match the original CAS Italian blank here in Wisconsin
You can purchase the keys from Catalina Yachts. They are $7.50 each.
jbd3
Done first thing this morning and thanks!
