I would like to install a propane tack in the Port propane locker of which there is none.
I would like to install the largest fiberglass one that will fit.
So has anyone installed a larger metal and or Glass tank?
A dock mate had an 11# fiberglass tank that I tried. The width was fine
but it was a fraction to tall. Looking for advice from someone who has been down this road.
Mark Alexander
SV M & M
Cat 350 #126
Kerr Lake NC
Propane tank
malexander24
Propane tank
Mark Alexander
SV M & M
Kerr Lake NC
#162
SV M & M
Kerr Lake NC
#162
Re: Propane tank
Nope, we have a second tank same as OE.
elk
Re: Propane tank
Do you mean that you want to hook it up with a regulator and hose? Or are you just going to put the spare tank in the port locker? I don't know why you would want to totally install a second tank, other than increasing the gas capacity of the system. But seeing how easy it is to swap out tanks when one runs dry...
I just bought a Worthington steel tank, an 11 pounder, from Amazon for $60 with free shipping, so if you go that route, there it is. They last 12 years before needing replacement, I believe.
Ed Kruzel
S/V Emily
#399
Cataumet, MA
Ed Kruzel
S/V Emily
#399
Cataumet, MA
malexander24 wrote:I would like to install a propane tack in the Port propane locker of which there is none.
Mark Alexander
SV M & M
Cat 350 #126
Kerr Lake NC
malexander24
Re: Propane tank
Been out cruising, just catching up. Heard someone say that they bought the fiberglass tank and it was easy to cut a little off the handle to make it fit heightwise.
S/v TRIUMPH
S/v TRIUMPH
