cockpit shower
Captain Kirk
cockpit shower
Post by Captain Kirk »
Last year I ordered a new shower hose and wand for the cockpit.
Trying to install it today and found the shower hose connection to the H/C mixer assembly was a problem. The threads on the plastic male connector on the mixer were stripped and the PO had jury rigged a connection. I'm looking to replace the mixer valve assembly to get this sorted our properly. Catalina direct say they can no longer get this item or the complete shower package ( plastic box, knobs wand etc)
Has anyone replaced their shower or components of it? There is unit that Amazon carries called USAMADE Stowaway Shower. Not sure if that one fits as a direct replacement. I'm looking further into that one.
Any input is very welcome, thanks
LI_Sound_Cat
Re: cockpit shower
Post by LI_Sound_Cat »
Kirk,
I have spent far too much time and money trying to solve the same problem - unfortunately unsuccessfully. Please let me know what you find. I am actually thinking about trying block off the hot water feed and turn it into a fresh water hose.
Dan
Dan
“Glandore”
#161
Monty
Re: cockpit shower
Post by Monty »
I was able to find the exact replacement from a dealer winter of 2021. When I return home I will try to find my records and should be able to share it. Give me a couple of days.
Steve Montgomery
Salty, hull #418
Deltaville, VA
Monty
Re: cockpit shower
Post by Monty »
The cockpit shower is by SSI plastics... customformplastics.com. It's called a Stowaway Compact Shower. The unit's number is SSI4860000. I found SSI had sold or was dealing through ReplacementBoatParts.com. I dealt with an Evan Love at 813-541-4454. I replaced the whole unit due to sun damage and a cracked cover. In the process I replaced the stiff rubber hose with a long flexible s/s hose to allow me to stand up and shower. Evan was helpful in getting me credit for the new rubber hose. Their website has the replacement unit as well as the mixing valve assembly. web address is https://www.replacementboatparts.com/tr ... spx?page=2 . The replacement unit is not inexpensive but then nothing is now. Hope this helps. Steve
Steve Montgomery
Salty, hull #418
Deltaville, VA
Captain Kirk
Re: cockpit shower
Steve et al.
Thanks for your input. I had looked at their site a few days ago and was getting excited. When I looked more closely, the complete unit they have uses a bigger box than mine; its wider by approx. 2". I did not see the mixer valve assembly but will contact Mr. Love. I could make my cutout wider as an option to use the complete unit.
My boat is a 2003 and apparently the unit I have was discontinued in 2004. If you got an exact replacement from them, you probably have the newer model.
Definitely this is good source to use and I'm hopeful now I can get something that will solve my problem. Thanks again!
Monty
Re: cockpit shower
Post by Monty »
I am a 2007 so they may have changed....it fits nicely in the side of the opening to step out to the swim platform. Evan was a big help to me so hopefully he can get you what you need. I checked the website, and my mixing valve was there...your's may be different given the size difference. Good luck.
Steve Montgomery
Salty, hull #418
Deltaville, VA
Captain Kirk
Re: cockpit shower
Hi Steve
I did contact Replacement Parts again and was told they just got more stock on the SSi unit that fits my cut-out. I ordered it right away, they may never get anymore of these.
So thanks very much for your input!
If anybody else is considering changing their older unit, they have them on their website now at about $200.00 which is a very good price relative to other types I've looked at. It comes with a 10 foot hose (plastic) and shower wand. I may do a change-out with a metal armored hose which is much more flexible and nicer to use; no kinks, it slides in and out and stores more easily.
LI_Sound_Cat
Re: cockpit shower
Kirk,
Do you happen to have the exact part number you ordered?
Dan
Dan
“Glandore”
#161
Captain Kirk
Re: cockpit shower
Dan,
The unit I ordered is:
SSI - Stow Away Compact Shower, - p/n SSI48600000
It shipped next day. Its on their website and they emphasize that the units they have will not last long. $219.00.
Cheers
Re: cockpit shower
Curious, does that mean they don't have many left and selling fast, or what they are selling "doesn't last long"??
Re: cockpit shower
Post by Olivia Mae »
Wow! They're pretty proud of that shower faucet. I did something like this with ours after I bought the boat and found out the previous owner didn't winterize the cockpit shower properly and the faucet cracked. I can't find the exact one I bought at the time, but this kit should work if it's 4".
https://www.amazon.com/Stowaway-transom ... 110&sr=8-9
Captain Kirk
Re: cockpit shower
Hello all
Getting back on this issue: the new unit has worked well, mostly. However this season a leak developed at the connection between the hose and the wand.
I taped it up to get through this past season and had a look at it today. The plastic threads are cracked and really just falling apart. The wand has very thin walls and it looks like they've just crumbled.
I'm looking for replacement that maybe has metal threads. Catalina direct have this wand in stock but I'm not happy with the quality, plus they want $64.00 for it.
Has anybody has found a better replacement wand? Its 1/2" ID which seems to be the standard size. A key point is that the shower head needs to be quite small to fit inside the enclosure.
Hope the attachment file works.
shower wand 1.JPG (237.27 KiB) Viewed 15546 times
Monty
Re: cockpit shower
Post by Monty »
I was lucky enough to find a shower handle at Lowes on sale for $10 when my original one broke. Fits perfectly....suggest you look there, Home Depot and the like.
Steve Montgomery
Salty, hull #418
Deltaville, VA
Captain Kirk
Re: cockpit shower
Hi Steve
Good find!
I'm searching Home Depot etc. on-line. They have literally hundreds of choices, most have a large head that won't fit into the shower enclosure. You got lucky finding one in-store at a great price.
I just tried Amazon and found a nice looking unit, its small and has a handy thumb slide for OFF to Full and it will fit in the enclosure for $11.00. I'll let you all know how it works, hoping its not a piece of crap.
