Engine Access Door
Barbara
Engine Access Door
Post by Barbara »
As you know, the engine is not easy to access (except from the front or the top of the back). Has anyone added a second side access panel or made the tiny door bigger in the aft cabin? It seems like there's plenty of room there on the side to make a second door or expand the mini one. If you have done this, do you have pictures or lessons learned? Thanks!
Barbara
#76 Freedom
Barbara
#76 Freedom
"Wherever we want to go, we go. That’s what a ship is, you know. It’s not just a keel and hull and a deck and sails. That’s what a ship needs. But what a ship is… what the Black Pearl really is… is freedom."
Re: Engine Access Door
Post by ElizabethG »
Hi Barbara,
I'm not sure what enlarging that access door will buy you that you can't reach with the aft cabin engine panel off.
I use that door to open/close the engine raw water through hull, quick check for leaks, etc. and that's about it.
Atlanta
Elizabeth G
#193
ElizabethG wrote: Sat Feb 05, 2022 3:52 pm Hi Barbara,
Atlanta
Elizabeth G
#193
Same here, plus access the rear port engine mount bolt.
What else are you wanting to access on the port side of the engine that would warrant cabinetry work?
