E80 Chartplotter Screen
nedenborough
Post by nedenborough »
My E80 Chartplotter has developed a hotspot right in the center of the display. It makes the unit unusable. I always cover the screen when not in use, but it looks like sun damage to me.
Is there a way to have the screen only replaced? Everything else works correctly.
Re: E80 Chartplotter Screen
The same thing happened to my C80 screen. I sent it to GuageSaver.com they refurbished it for $150 plus tax and shipping.
Before and After:
C80 Restoration2.JPG (129.94 KiB) Viewed 12341 times
NormSail350
Post by NormSail350 »
Hi,
I did not repsond because I have a Garmin plotter (older model). My screen looks similar, but is due to minor water condensation. I called Garmin and their asnwer was - it is a discontinued model, so you will have to buy a new one. The Plotter works, but is just irritatingly unclear so it went down on the priority list (not worth spending $1500+ for new espoecially with Novionics ad cheaper ipads with GPS that are available.
I will definitely check out GuageSaver.com as well.
NormSail350
Escape (Hull #40)
Palmetto Bay FL
NormSail350
Escape (hull #40)
Palmetto Bay, FL (Miami)
I had a similar problem, went on Ebay, bought the exact chartplotter for $250 and it was plug and play, and a quick fix. No need to run new cables and anything.
Post by cuthbert »
Try this guy, he fixes other raymarine screens, just did my ST6002 Autopilot head when it went black in the middle.
C250@mydurango.net
nedenborough
Thanks for the reply. I have sent him an email to ask if he works on E80s
nedenborough
I did look on eBay. You are right there are several there. Nothing as cheap as $250, but not bad.
I am going to see if I can find a repair for mine first.
Thanks to all for the replies
