replacing electric motor
Post by nybor »
Hi. My unit died. (i was going to give it a proper "burial at sea", but why pollute...
anyway, I got the new motor, but I am having a hard time removing the old one from the macerator blade. there is a nut holding it onto the motor shaft, but how to loosen it is beyond me. Maybe you don't have to to get it out of the housing. Not sure.
Any ideas?
thanks
ps. shoot. I should have signed it "ken". I would then get.....100,000...1,000, 100... 10... 1...0 responses. so I stand by dave
jking
Re: replacing electric motor
Post by jking »
The nut comes off counterclockwise. Its stiff but it will come off. Use something to hold the blade so you don't cut your fingers trying to stop it from turning. Once you get the nut off the black seal will also be difficult to remove, I had to destroy my seal to get it off. It seems like the black seal is part of the white plastic, but its not, they come apart. I have attached a parts view. I am a toilet expert after 7 toilet surgeries. You will most likely need a new black seal on the motor shaft. Defender Sea Era Electric repair kit #503014 has a whole bunch of parts including the little black seal (part #31-102).
When it comes time to replace mine I am going to seriously consider the nature's head composting toilet.
Jan #303
Post by nybor »
Thanks! I have the illustration you attached. I finally called Raritan and they said it should slide off easily. Sure enough, once I scraped off the calcium buildup (wow), it did slip off.
So, now to put it back together.
I can't believe how much dealers want for a new toilet! I would have just as happily gotten a hand pump unit. But, since if came with the electric....
Thanks again for the response.
ps. I ordered a new seal as well as some other items. I may go to Defenders and get the repair kit you mentioned as well.
