On the current setup there is is no block at all neither on the back of the boom or at the mast end.
I have attached few pictures of our current setting (Mast and boom setup) and also attachment point at the mast end
Not that we are not experiencing any friction but never tested under very strong (so far only 15-20 knots) but from experience, yes a reef should be taken ahead of time but hey who has not taken the reef a little too late
So I guess 2 questions for the more experienced sailors here :
- Is there anyone using blocks to limit the friction? (Aware that if a block we would complexify and potentially prevent the mainsail to go all the way down)
- At the mast end, I found is strange to have the reef line attached that way, with a simple shackle on a ring, I thought it would be more natural to have the line going down back as it would offer a purchase of 2:1 to mimic the end of boom as the line goes up the eye and comes back down as you can see on the photo
End of boom: Showing the 2:1 purchase and the potential friction as rope on rope with an angle (potential improvment with a block, or else) On the mast end: Showing that there is no purchase as the shackle is attached to a ring directly On the mast end: Showing the rings, one on each side so when pulled hard on one side the other ring is pull against the eyes on the Mainsail.
