raw water pump replacement
LONGHAWK
Post by LONGHAWK »
I have had a small leak from the raw water pump, and now the housing is showing signs of rust. I have identified the Universal replacement pump and also believe that Sherwood pump is the manufacturer. Has anyone purchased a Sherwood or only used the OEM Universal pump?
LONGHAWK #173
I'm nearly positive that Sherwood makes the water pumps on the M35 engine.
There is an interesting discussion on the C34 web site about leaking Sherwood water pumps. You may want to check it out - http://c34.org/bbs/index.php?topic=3974.0
Hope this helps.
LONGHAWK
pump
Post by LONGHAWK »
Interesting item I learned. the Sherwood pump (G908)is as expensive as the Westerbeke OEM pump(042175)(same item) , but the Westerbeke / Universal comes with more attachments / gaskets, etc.. I plan on picking the Universal pump up this weekend and will confirm this info.
