Plugged Refer Side Door Drain
BJH
Post by BJH »
On our 2005 350, behind the side door of the refridgerator there is an extrusion (think gutter) to catch condensation. The small drain hole in the center is plugged making the condensation overflow and ending up on the floor of the galley. I tried clearing it out with a wire tie without success and plan to go back down today with a coat hanger, different sized stiff wires, and other implements of destruction but figured I'd ask if anyone had any advice. Thoughts?
BJH
Miss Sea-ducer, Hull 329
Pasadena MD
Re: Plugged Refer Side Door Drain
If your coat hanger fix doesn’t work, try a can of compressed air like the stuff you buy at office supply stores.
BJH
Post by BJH »
I think I got it worked out. I really don't know where it drains to but I ran a stiff bailing wire down through it a few times and then took a West System syringe, wrapped electric tape to match the hole and blasted a bunch of water down through it. It appears to be opened up now, water is draining out. For good measure I put a syringe full of Clorox down through it to eat up any funkies.
BJH
Pasadena MD
