I wanted to sleep in the V-birth with my feet towards the bow. Then my head can be directly below the breeze coming through the hatch. Seemed like I would be chasing pillows all night, that fell off the bunk. So I made a simple head board, actually two separate removable and stowable head boards. Using 12” x 3/4” pine and then a hard wood strip and 4 wood screws to connect the two. The two pieces fit tab A into slot B for use as a head board. To stow, simple pull out the vertical piece and slide both up under the mattress. We used it for two nights and neither one of us lost a pillow. Please find attached a couple of photos. Other ideas are welcome.
Dana and Nancy
Hull #78 (2003)
Head board to control pillows in V-berth
SeaBreeze78
- Two pieces separated
- 20198504-C6A0-4B0E-8C0D-26ECD578BD8E.jpeg (25.13 KiB) Viewed 9301 times
- Assembled for the night
- A74A0803-EF12-4984-B7C6-15CFAA187EFD.jpeg (26.46 KiB) Viewed 9301 times
Re: Head board to control pillows in V-berth
Great idea. I've rescued many a pillow off the floor in the middle of the night.
SeaBreeze78
Below is a little closer shot of the the two pieces. The dark wood is Hard wood on the outside strip. Fingers give you a sense of size.
- B859322A-A55E-4CBC-806C-5CE9CA785AB6.jpeg (68.06 KiB) Viewed 9267 times
