I like the aesthetic of underwater lights. Nearly everything I have seen available requires drilling through the hull (not happening unless its a necessity) so I am warming to the idea of wiring some underwater LED lights into the swim ladder this winter. Therefore when the ladder is down to access the dinghy etc I can leave the lights on to find my way "home" in a mooring field after refreshments at dinner etc.
Anyone done this?
JC
Swim ladder lighting
Re: Swim ladder lighting
If you do that, make SURE that the power is totally isolated if in salt water or you will set up massive galvanic corrosion.
