Chain Plate Crack
Chain Plate Crack
I was polishing my stainless steel last weekend and I think I discovered 2 mid starboard chain plate cracks. It looks like the cracks propagated where the welding started and stopped.
- Chain Plate Crack #1
- IMG_1234.JPG (23.33 KiB) Viewed 5194 times
- Chain Plate Crack #2
- IMG_1233.JPG (28.14 KiB) Viewed 5194 times
Lagniappe, Hull #385
Re: Chain Plate Crack
It is possible for Stainless to crack if not welded properly. If you know a good welder that can TIG weld. Take it to them, they can grind it and re-weld.
