Engine Gauge Panel Replacement
S/V Serendipity
Post by S/V Serendipity »
If you are looking for a replacement panel for your gauges contact Kevin at Martek Davits in Clearwater Fl. We recently bought davits from Martek for Serendipity. We went over to see the shop and pick up the davits. While we were there we saw panels with gauges and it turned out Kevin also makes the replacement gauge panels. Later when we put Serendipity on the hard to redo the bottom we sent our panel to him so he now has the pattern to make more for the 350. The new panel is black with a carbon fiber look.
happy sailing
Bart, Trish and Sailor the boat dog
Re: Engine Gauge Panel Replacement
Bart, were you quoted a price for the replacement panel? Mine is starting to look pretty bad too.
S/V Serendipity
Ken,
You will need to contact Martek in Clearwater. I sent the entire panel to them and they made a template so there will be a price difference as it should be easier to make the replacement panel now. I will attempt to post a picture soon.
Bart
