Idiot Lights
yodagwb
Idiot Lights
There are two red warning lights in the instrument panel at the helm. When the key is turned on the warning buzzer goes off until the motor is started. My red warning lights are not lighting up when the buzzer is on while starting. I don't remember if they use to light while starting and are no longer working or if they don't really come on until there is a problem. Obviously to much wine. So before I get crazy and start pulling things apart in search of an answer, has anyone noticed?
pdenoncourt
Re: Idiot Lights
Mine have never come on when the key is on. I believe these are engine temp. and oil pressure warning lights. I know the engine temp. works because my cooling water pump failed and it came on then. Don't recall ever seeing the oil pressure light on.
Peter Denoncourt
Kite, C350 #72
Peter Denoncourt
Kite, C350 #72
