Evaporator door
lyle
Evaporator door
I am thinking of installing a door on the evaporator unit inside the freezer compartment. The intent would be to keep only the goods inside the evaporator itself frozen and I would think the fridge should be more efficient. The cold air inside the evaporator would not just spill out like it does now. (IMHO the evaporator should have been mounted with the opening at the top for maximum efficiency of the unit and for ease of loading and unloading it.) I added a small insulated styrofoam cooler inside the freezer compartment for cold beer which works well (it does not freeze inside the cooler).
Re: Evaporator door
Lyle,
If you decide to put a door on the evaporator, let us know how it works out. If you are going to drill holes in the evaporator to hinge a door, be VERY careful where you drill. If you puncture a cavity carrying freon, it could be a very expensive mistake.
lyle
Re: Evaporator door
I am looking at either attaching the door to the sliding plastic tray in the evaporator (some kind of basket would be required to keep everything from falling out when you opened the door) or attaching hinges to the side of the ice box - the evaporator is right up against the edge of the icebox so it would probably work.
