Aft locker latch
Aft locker latch
Has anyone replaced the recessed latch on the aft cockpit lockers? What did you use? The key lock and latch mechanism is not necessary.
Re: Aft locker latch
Post by tranquil »
Can Purchase at Catalina Direct
From the Home Page go to By Boat and select 350
Then select Hatches & Ports
Then select Replacement Parts
Suggest taking a photo of the existing hinge and compare. Elsewhere on the site are the same hinges with rounded corners. The above have sharp, square corners. I dont remember which corner style is on the aft hatches; think is sharp square if my memory is correct. The transom hinges are rounded corners; if my memory is correct. My boat is on the hard under cover. Good Luck!
Teri Weber
Tranquil
Hull #187
Chicago
Tranquilcat42@yahoo.com
russp
Post by russp »
Hi Gary,
Not clear on what part you are looking for. Assuming hatches at either side of helmsman position accessing the deep lockers, mine just has "pull/hatch lifters" which had corroded and I replaced some years ago but can't find out from where. From memory the latches to the transom hatch covers, and the large sail locker hatch cover are different again. Maybe if you post a photo of the part you are after?
I am not at boat, but I think we use something like this for rear cockpit hatches?
https://www.bcf.com.au/p/lift-ring-chro ... s1AaDfUdzg
russp
Post by russp »
Finally returned from our short trip down the coast and have begun repairs. I removed the old corroded hatch ring and ordered a small flush ring that seems to fit nicely in the circular recess. The issue is that it does not cover all the gelcoat damage and I plan to use this repair as a test project for making minor gelcoat repairs with a small Preval sprayer. Does anyone have any experience with something like the Preval sprayer? Where is the best place to buy gelcoat in small quantities?
ring pull.png (43.77 KiB) Viewed 562 times
Latch 2.png (209.43 KiB) Viewed 562 times
Latch 1.png (45 KiB) Viewed 562 times
Post by ElizabethG »
G & J,
Catalina Direct sells a patch kit to repair gelcoat damage; https://www.catalinadirect.com/shop-by- ... hResults=1
This particular paste is for boats made between 1995 - 2004. I've used it several times on my 2004. For me, it was a perfect color match.
You mix it with a hardener and it's about the consistency of peanut butter. Easy to use and instructions are included.
