A?C recommendation
Post your technical questions or solutions about your boat's air conditioning here.
Monty
A?C recommendation
Post by Monty »
My AC (Dometic DTU16-410A) has died with a Ground Fault Trip that we can't identify the source from and assume its internal to the compressor or other difficult to isolate source. It is 6-8 years old. It is not the pump or AC supply line as they have been tested. Any recommendations for new brand/model? Anyone else have the GFI issue that was repaired?
Steve Montgomery
Salty, hull #418
Deltaville, VA
Re: A?C recommendation
Post by ElizabethG »
Hi Steve,
If you want to check the compressor itself, go to YouTube and in the search bar type in "testing ac compressor with multimeter". You'l find several good videos.
modesid
Post by modesid »
I have used Ocean Breeze OB18.5 120v units in both my C34 and now my C 350. This company is great on service and Technical support. The OB18 is the only 18000 btu unit that is 120 v I think.
My boat is located in Fl and I spend a lot of time in the Bahamas and this size keeps the boat really cool. Ocean Breeze is located in Stewart Fl and Alex is the go to on everything.
Wind Dancer
Daytona Beach
Haul 0011
ethonbrook0707
Post by ethonbrook0707 »
It’s interesting to see how other Catalina 350 owners approach upgrades and maintenance while keeping the boat practical for cruising.
