Fuel Lift Pump Help Needed
starfish
Post by starfish »
Good afternoon, all,
While motoring today my 350 sputtered and finally stopped. I am "hoping" it is just the lift pump.
Can anyone tell me if: when the key is turned on should the fuel pump be hissing or humming?
Mine is doing nothing. When I remove the fuel line to the injectors from the lift pump and crank the engine I have no fuel pumping
into the lines or out of the lift pump. Is there a fuze? What am I missing.
If it is the lift pump, where is the best source for a new one?
Thanks very much
Ed
2005, 350 #333
Ed Kleinstuber
s/v Starfish
C350 #333
OBX,NC
J Kleber
Re: Fuel Lift Pump Help Needed
Post by J Kleber »
The lift pump is wired into a circuit with the oil pressure switch and the ignition switch in the 3rd -glow plug- spring back position. It's designed to pressurize the fuel on starting and then act as a safety when running. Confirm you have the alarm buzzer and oil pressure light with the ignition on. And also if it's running in the preheat position, or check wiring. You can find the lift pump at your auto parts store, Amazon, or marine supply.
starfish
Post by starfish »
Thanks very much. Can you tell me if the pump is supposed to make any kind of noise with the key on, like it's trying to pump? And yes, my alarm buzzer is attached and working. I also noted that the fuel filter and water separator was empty when the boat stopped running. Is that part of the lift pump mechanism? I have also ordered a Westerbeke Breaker Circuit pn: 024683 in hopes that it might have tripped or fried.
Whatever additional help you can offer is greatly appreciated.
Ed
Ed Kleinstuber
s/v Starfish
C350 #333
OBX,NC
Hans v. d. Weijden
Post by Hans v. d. Weijden »
The problem with the fuel pomp not working could be corrosion of the connector. After eliminating other causes of failure we decided to disassemble the pomp. At that moment the wire came loose from the connector. So we found the cause of the problem.
Hans v. d. Weijden
Swan
C350 Hull 254,
Ermelo, The Netherlands
Hans raises an important point. Any time you have an electrical device that isn't working, one of the first things to do is to tug on each of the wires that has a crimp type connector and make sure that the wire isn't corroded and is still firmly seated in the connector.
starfish
Post by starfish »
To all responders,
Thanks very much as always in helping me diagnose the issue. As it turned out, I replaced the lift pump and all is good. She is purring like a kitten. The lift pump ended up being an original equipment so I am not at all surprised it has failed at this point.
Once again, thank you for all your suggestions and support.
Ed
Ed Kleinstuber
s/v Starfish
C350 #333
OBX,NC
