replacing Bilge Pump
Posted: Fri Feb 28, 2025 4:38 pm
Greetings forum,
On my 2005 #333, I am replacing my bilge pump and separate float switch with a bilge pump with a built in float switch. So I currently have 2 wires to the pump and 2 wires to the float switch. However, when I attach the wires to the pump I can''t get it to work, it works just fine if I change from Auto to Manual on the board, but nothing on Auto.
Can anyone help me with the proper wire setup? Directions are useless!! My new pump has 3 wires Black for Neg, brown and white for Auto set up and solid brown for manual. It is a Maxzone 1100 with float switch. Here is the link via Amazon: https://www.amazon.com/dp/B072JKFV9Z?re ... title&th=1
Thanks for any help offered.
Ed
Ed
