Bimini Parts for New Solar Panels
Posted: Sat Mar 05, 2016 11:25 am
We added 4 100w solar Renology Panels to hull number "007" and one 65 Watt panel to dingy that is powered by 45 lb thrust Minn Kota Motor. In order to reinforce the Bimini we needed many connectors. The best place I found for end caps, hinged jaw clamps and jaw slides was http://www.ddthreadsplus.com
Al Baumgartner, Owner
D&D Threads Plus
298 Coon Rapids, Blvd. NW
Coon Rapids, MN 55433
P: 800-365-0691
F: 763-784-0175
You can call Al, and they answer right away.
End caps with an eye are $6.84 and part number 88397SS w 2 set screws
Hinged jaw clamps are $13.70 #883661SS
Jaw slide heavy duty 2 set screws $6.84 #88399SS.
I like his parts best because some of them have 2 set screws. I could not get 90 degree elbows from him.
Also, I asked Renogy for a discount while on the phone and they lowered the price by about 7 percent. I did not go through Amazon because I wanted to talk to them on the phone. I talked to them several times.
D&D Threads Plus
P: 800-365-0691
F: 763-784-0175
