Losing propulsion - engine or prop?
Posted: Fri Oct 17, 2014 9:26 am
I'm not sure if this is an engine/transmission problem or a prop problem, so I'm hoping to get some insight and advice. I have hull #5, so the boat is 12 years old. While driving under power into heavy seas on several occasions, we've lost propulsion. If we turn around and go with the seas, or tack through the seas on an angle at a slower speed, we're o.k. When the propulsion is lost, it seems that there's a bit of noise and vibration underfoot (by the prop?), and I watch the speed drop. Once I put the engine in neutral and then into forward, it will bite again, but would sometimes lose propulsion again. It seems to be in heavy seas and going directly into the waves. It happened at 1800 to 2200 RPMs, but also at a slow speed going up to a mooring.
I have Autoprop and thought it was a problem with the prop or prop alignment. Then someone said maybe the transmission is going. But, I've had many successful hours of running in normal conditions without the problem. I have a new shaft (5 years old) and the cutlass bearing was fine in the spring. There doesn't seem to be any vibration or misalignment in the shaft when the boat is in gear.
Thoughts?? I heard people complain about Autoprop and cavitation, so I almost bought a Flexofold prop at the boat show, thinking that might be the problem. Then, I was advised to make sure that I've identified the problem properly. I'd love to get your advice on this.
Jan
Seaquel
Hull #5
Jan
Seaquel
Hull #5
