Engine Cover
Paul
Engine Cover
Post by Paul »
Could someone measure the length and width of the hinged engine cover located just below the compaionway steps.
Our boat is a 2003. I dont know if that makes a diffrence or not.
Thanks!
Paul
Re: Engine Cover
Ours is about 12" from the hinge to the inside edge of the forward fiddle, and about 24" wide inside the side fiddles. There is another 2" behind the hinge to the bulkhead, so the entire area is about 14" x 24".
Paul
Re: Engine Cover
Post by Paul »
Thank you!
