Companionway boards
Posted: Fri Oct 18, 2013 7:50 am
by Paul
We are about 100 miles away from our boat and I would like to make a one piece board to insert over the winter months. I have the templete of the the size but i forgot to measure the thickness of the boards.
Anyone near there boat that could give me that dimension?
Paul
Re: Companionway boards
Posted: Fri Oct 18, 2013 10:57 am
I"m nearly positive that they are 3/4" thick. I'm going up tomorrow and will confirm.
Posted: Fri Oct 18, 2013 1:24 pm
Paul,
Just measured the thickness of hatch boards on our 2004 350: 15/16".
Probably started as 1". Suspect 3/4" plywood would work just fine.
Posted: Sat Oct 19, 2013 11:22 am
I can also confirm the 1" thickness. Please note the term "nearly positive" in my previous post.
Posted: Sat Oct 19, 2013 1:54 pm
by DuncanMcMillan
The gap is 1 and 1/8 and the boards are 1". |
Posted: Sun Oct 20, 2013 10:02 pm
by Paul
Thank you all!
Posted: Wed Dec 23, 2020 1:22 pm
by cuthbert
Rather than start a new post I was searching and thought I would tack on the back of an existing one......
Watching "Distant Shores" (If you can find this on a cable channel I would recommend it) they had just taken delivery of a new southerly and it had a single sliding board in perspex or similar for the companionway, which strikes me as a great idea.
I have previously looked at zocor doors etc as a replacement for boards but ideally I want to have the boards to secure the boat, but when on the hook the boards are sub optimal and what I want is to have a single see through stiff sheet that drops in the slot. Anyone done this?
I don't need it to lock and although sound blocking is desireable I think a 15/16" thick sheet would be overkill so something thinner (1/4"?) with means of not rattling in the slot so 4 standoffs or similar. If anyone has done this please do share.
