Catalina cockpit table
Posted: Mon Jun 10, 2013 8:13 pm
by JOEDIG
I am looking to add a Catalina Cockpit table.
I located a table off another Catalina model and would like to compare sizes.
Can anyone give me the center length and open width of the 350 table along with the length of the stainless base? Also, how is it mounted? Screwed into the cockpit floor? Through bolted? Screw/bolt size?
Thanks!
Re: Catalina cockpit table
Posted: Tue Jun 11, 2013 10:41 am
by wcconway
28 1/4" x 39 1/2 table (each leaf extends and wraps around the pedestal). This adds 6 in to each leaf.
Stainless steel legs are 2 ft.
The braces that hold up the table leaf have broken twice. Has anyone used a different, more stable brace?
Will follow up with pictures.
Posted: Tue Jun 17, 2014 2:57 pm
by chesworth
I've had same problem with the cord in brace breaking. By the time Catalina gets a replacement to Canada it costs over $50. Ideas welcome for an alternate and a method to repair. I have noticed that there is less stress on cord if brace is folded downwards rather than upwards.
Posted: Tue Jun 17, 2014 3:52 pm
These will probably also be close to $50 by the time it is shipped but Catalina Direct is the only other place to buy these that I know of.
http://www.catalinadirect.com/index.cfm ... rt-arm.cfm
Posted: Wed Jun 18, 2014 7:10 am
by R.B.
I have gone to the local hardware store and picked up some thin shock cord. A couple of bucks for 20'. I then removed the 2 halves of the support from the table, disassembled each section, tied in a the new shock cord and reassembled. If I remember correctly, you do need to pre-tension the cord when you get it in the 2nd support. It has been a number of years since I did this repair, but I think the supports just screw apart. Someone jump in here if I have this wrong.
Posted: Wed Jun 18, 2014 9:03 am
by Triumph
You are correct, just change out the shock cord. Did mine two years ago for a cost of about $3.
Posted: Wed Jun 18, 2014 12:19 pm
by Air Mobility
Anybody have a source for the cockpit table pictured in this string?
George
S/V Air Mobility
Hull 158
Posted: Thu Jun 19, 2014 7:21 pm
by JOEDIG
Can anyone tell me how they screwed in the cockpit table?
The table came with 1 1/4" machine screws - Is this right? No bolts or washers - just drill a hole and screw them in?
Thanks, Joe
Posted: Fri Aug 01, 2014 7:04 pm
by davidjohnson708
JOEDIG wrote:Can anyone tell me how they screwed in the cockpit table?
Thanks, Joe
Sorry, I couldn't reply sooner. There are two metal plates embedded in the cockpit sole. If you center the table and place the aft end about 4 inches away from the steering pedestal, you "should" hit the plates when you drill. You will need a tap for the threads. Don't drill through the deck.
