Forum Timeout Limitation
Posted: Wed May 25, 2011 9:03 am
by wcconway
Did you know when you manually login to the forum, there is a timeout period for that "session"? At the end of the timeout period, you will be logged out and will have to reauthenticate. This could be a real issue if you are in the middle of composing a post becuase all data will be lost unless you saved it periodically with the "save draft" button.
To eliminate the timeout constraint, consider using the "auto login" function. Or, at the very least, be sure to save your drafts often or compose the post in a word processing application and then copy and paste into a post.
