Cleaning Rub Rail
Posted: Sun Sep 26, 2010 1:21 pm
Has anyone found anything to remove the black mold from the rub rail? This weekend I tried Soft Scrub, bleach and Jomax, undiluted bleach and viny/rubber cleaner. It's looks a little better but still has a long way to go.
What's your favorite?
Re: Cleaning Rub Rail
Posted: Sun Sep 26, 2010 8:24 pm
by Allsail
Ken,
Mr Clean Extra Power Magic Erasers will remove the mold with a lot of elbow grease and a number of pads.
And while it's not magic, it did completely remove the mold.
Like u, i had tried a number of concoctions w/o success.
Sam's carries a canister of 10 at a reasonable price
AB #326 X-Factor
Posted: Fri Jun 20, 2014 3:27 pm
by Chuck_on_Hudson
Acetone works great - use rubber gloves and cloth rags. Avoid rubbing the hull or else you will dull the wax on it.
Posted: Sat Jun 21, 2014 6:17 am
Chuck_on_Hudson wrote:Acetone works great - use rubber gloves and cloth rags. Avoid rubbing the hull or else you will dull the wax on it.
You must have different mold that me. :D Acetone was also a "no go".
