Jib Tack Shackle & Pin Size?
Posted: Mon Sep 07, 2009 4:18 pm
by Bob Hart
While sailing a downwind run causing a lot of jib flapping/snapping in heavy wind, the tack shackle just disappeared, letting the jib tack flap in the breeze! Now that it's gone, I don't know the replacement size. Anyone have that info. (it's not in the C350 manual)? I have the 135% roller furling Genoa Jib.
Re: Jib Tack Shackle & Pin Size?
Posted: Tue Sep 08, 2009 8:30 am
by R.B.
Hi Bob,
I am not sure of the size but here is a picture of mine. Maybe you can use a ruler to figure out the size using a ratio to your lifesize furler.
Posted: Tue Sep 08, 2009 9:34 am
by Bob Hart
Well, that's more than a simple shackle & pin. I don't see how I could've lost all that at the same time. I must have had a simpler arrangement.
