Sheet Sizes for Berths
Posted: Thu Nov 17, 2005 5:22 pm
by Tim April IV
This seems to come up a lot - I dug up a post from a while back with the following sketch of the forward berth measurements.
We measured the matteresses and decided to buy a fitted Queen size set for the fwd cabin, and to wait on the aft cabin as we currently don't sleep there.
Both matteresses measure appox 6" thick.
As shown, the matteress in the fwd cabin measures 77" from fwd to aft along the center of the matteress. At the fwd end, it is about 27" wide measured port to stbd. At the aft end, it measures 46" port to stbd. At the widest point, the matteress measures 58" port to stbd.
This "widest point" occurs 37" from the aft corners and 44" from the fwd corners.
The matteress in the aft cabin is 54" wide measured from aft to fwd. Measured from port to stbd at the aft side it is 78". From port to stbd at the fwd side it measures 86".
Sweet Dreams!
Posted: Fri Nov 18, 2005 8:26 am
by Triumph
Thanks Tim, I was about to tacjle this project, your scetch and measurments will make it a lot easier for me.
Sheets from Catalina
Posted: Fri Nov 18, 2005 8:20 pm
by c350makeway
Tim,
Many thanks for the measurements. I purchased the fitted sheets from Catalina, that is they were a give away and final point of negotiation to close the deal on my purchase of the boat.
The OEM sheets fit well and have a reasonable thread count, however, if one is looking to spend a substantial amount of time under the sheets rather than under sail, one may be wise to select sheets with a higher thread count such as 600 vs the Catalina issue.
Armin
s/v "Make Way"
Flannel in the Northwest
Posted: Sat Nov 19, 2005 2:05 pm
by Tim April IV
Here in the northwest, we really enjoy our flannel sheets - in the winter they make that bunk real cozy.
Re: Sheet Sizes for Berths
Posted: Sun Aug 07, 2022 2:21 am
by Kerdel
Hi,
The perfect size for bedsheets in fwd cabin is,
V Berth (1) Fitted Sheet 88”H 82”L 20”F, (1) Flat Sheet 102”H 110”L 40”F,
XL V Berth (1) Fitted Sheet 102”H 82”L 30”F, (1) Flat Sheet 102”H 110”L 40”F,
This size is close to Queen bedsheets size but not the exact as the mattress wall is 32cm to 34 cm , if fitted sheet wall is less then 34cm then it wont fit perfect,
In your given dimensions the mattress thickness is 6 inches which is lower then you have to get custom made as the sizes which are available are ready to purchase are different, only flat sheets can only be used. I am from Australia and our Queen size fitted wall size is 40 cm and it is impossible us to fit that on fwd cabin mattress.
The solution is purchase custom made bed sheets and it will cost $60-$70 and available in Queen bed sheets Australia.
flannelette sheets can only be used in winter and it is hard to clean and mostly people use vacuum to clean it
