replacing/rebedding Stantions
Posted: Mon Mar 02, 2009 7:46 am
I was checking on my boat which is stored for the winter this past weekend, and noticed that my port side, middle stantion was bent inward a little. I investigated and noticed that the weld had completely broken where the stantion meets the base. I figure the strong winter winds must have pushed enough on the plastic tarp to eventually break the weld.
Questions:
1) How is the station fastened and then removed from the deck. There are 2 philips head screws on the inboard side of the base. Are there any fasteners from underneath the deck?
2) Can the lifelines be unscrewed from the turnbuckles and the pulled through the stantions? If not how do you feed the lifelines through the stantions?
Questions:
