Have you checked your water pump impeller recently?
My boat is half way through its fourth season with 181 hrs on the engine. Lately I noticed that the engine temperature was creeping slightly over 180 degrees when motoring at 2700 RPM's. A friend suggested checking the water pump impeller. I was shocked to see that it was on the verge of self-destructing. I was able to get 5 or 6 years out of an impeller on my Catalina 34 and even those looked barely worn.
If you haven't check yours lately, take a look.
EvenKeel
Re: Have you checked your water pump impeller recently?
Post by EvenKeel »
Ken-
That really doesn't surprise me at all. I've had impellers go out in about that many hours. It was no fun fishing blades out of the heat exchanger.
I check mine every year during winterization, and if it looks worn, feels stiff, or if the smallest crack appears at the base of any blade, a new one goes in. I also like to put a thin layer of vasoline or lanocote inside the pump at the end of the season so that the blades don't stick and break on first start the following spring.
Gary
Even Keel II #288
