Tempoarary Shaft Zincs
Posted: Sun Oct 07, 2007 12:46 pm
I recently had a Kiwi Feathering Prop installed and it works very well especially in reverse. But it has a cone which precludes attachment of a cone zinc. As well it does not allow enough space between the end of the skeg shaft housing and the start of the prop hub. A regular collar zinc is about 1" thick and there is about 3/4 inch available. I have a couple of options and would appreciate any input/suggestions. One, I could shave the skeg fibreglass housing about 1/4" and then fit the collar zinc. There appears to be about 1/2" of skeg fibreglass protruding before the cutlass bearing is visible. Second, the Kiwi prop vendor has come up with an idea of cone extension and they are working on that but who knows how long? I put the boat back in the water rather than having it blocked up whilst this problem is solved. I will have to use a diver when we finally sort it out.
I checked with Kiwi and they say that the prop is all stainless and kevlar/ plastic and is not subject to electrolysis. I think the shaft is also stainless. But I feel nervous about not having zincs on the boat. I think the through hulls are all nylon and there is no other metal? What about the Rudder shaft?
So in the meantime, until I get one of the above, I am hanging a zinc over the side. I bought a "grouper zinc" at Westmarine but it only has 15" of wire line, supposedly galvanised steel, and I have attached it to the stern backstay for now. However I cant see that the backstay is connected to any earth so it may be useless. I was thinking of adding more wire line and leading it to the engine block which would mean about 25"between the zinc and the block. Would this be ineffective as it is too long? One marina observer says that the zinc needs to be near the next weakest metal and should be a short length from the grounding location. It should not be as far away as one of the mid ship shrouds. Am I correct in thinking that the shrouds connect to the boat's grounding system?
Until we get it sorted out, fellow 350 owners need to be cautious about the Kiwi props. I had one on my 320 and it was remarkably better in motoring boat speed and in straight line reversing. They are half the price of Max Props and much easier to maintain. Where we have rogue logs and difficult currents in marinas around here in the Pacific Northwest they are invaluable.
Thanks in anticipation for comments, cheers, Geoff (# 392).
