Do you know what this cable might be?
Posted: Sun Oct 05, 2025 3:03 pm
While upgrading out electonic systems, I found this cable and connector in the clam shell above the aft cabin. Apparently, at some time it may have gone up the pedestal. The cable runs aft to the transom, then over to the upper channel on the port side heading forward.
Obviously, it is not connected to anything, and if I could find out where it might have gone to, I might pull it out so that it doesn't confuse me anymore.
