Clearance for Prop / Shaft Removal
Posted: Mon Jan 15, 2007 4:53 pm
Well, we bumped a log or something pretty hard over the winter holiday and the diver says we bent the shaft. I was figuring it was going to be a messed up prop, but she says "prop's OK, you bent the shaft".
Yard guy say he needs to know if the prop/shaft can be removed without dropping the rudder.
From what I can see in pictures, there seems like there should be sufficient clearance but I haven't measured anything. I'm still reeling from the rough estimate he ran through.
Can the prop/shaft be removed without dropping the rudder?
Thanks for your help!
