Replacement Salon Light Switch
Posted: Thu May 30, 2024 12:06 pm
I think the switch on the light pictured below is bad. Has anyone found a replacement switch? I'd rather do that than replace the fixture and have an odd one that doesn't match.
Re: Replacement Salon Light Switch
Posted: Thu May 30, 2024 12:59 pm
Ken,
Wonder if it would be good time to upgrade the the newer LED lights. They are a LOT better than the first generation LED's.
Power savings is substantial!
Posted: Thu May 30, 2024 1:41 pm
Brett, I replaced the old halogen bulbs with LED’s a couple of years ago. With nearly every one turned on the ammeter barely moves. BTW, the pic I attached was scavenged from the internet. Being on fresh water my fixtures look nearly new.
Posted: Thu May 30, 2024 1:46 pm
Ya, the pictured fixture looks like it lived in a very humid environment for a very long time.
Glad that isn't yours!
Posted: Thu May 30, 2024 6:40 pm
by ElizabethG
Ken,
Dang...I wish I had seen this earlier today when I was at the boat.
I plan to go back in a couple of weeks after my motor mounts are replaced and the prop shaft realigned.
If you can hold out until then, I'll bring you one back.
Let me know...
Posted: Thu May 30, 2024 9:06 pm
by russp
I haven't tried, but I imagine it is just a very small single pole switch you would get from Tandy??
Posted: Fri May 31, 2024 8:45 am
by Monty
Ken: I have had two switches go bad. I found a direct replacement with LED lite bulb and a more substantial switch. I think it was at Catalina direct. Steve
Posted: Sat Jun 01, 2024 5:31 am
Thanks Steve. I'll check that out.
