Maxwell 800 chainwheel 108 - chain type
Posted: Wed Aug 31, 2022 11:55 am
Like many of you we have a Maxwell VW 800. Ours has the 108 Chainwheel (108 is stamped on the lower half facing upward, cant miss it)
I have been everywhere trying to get a correct answer on the correct chain for the 108 wheel. Finally on the phone with Vetus Maxwell 1-410-712-0740
I got a guy willing to dig into the archives and find the 800 and CW 108.
His answer was 5/16 high test G63, or DIN 76 - 8mm, or 5/16 BBB
Ours was set up by one of the two previous owners with 5/16 G4 which is actually for chainwheel 105.
It works and obviously has, but I have had my doubts and as I wish to change the chain so I very much wanted some clarification.
What do you folks have for chainwheel 108 chain type?
Thank-you
PS- Just did a full overhaul on the 800. Will share some tips and tricks and pics asap. In case I don't, I echo the recommendation that shaft seal SP708 be changed often.
Given what I found I will be doing this annually. It installs thick body up and compressible flange down.
Thank-you
