AC runs, no error message, but takes a rest for a while, and then works again
Posted: Fri Aug 26, 2022 3:03 pm
Hi everyone,
My AC works and cools, but runs for a while then stops (water pump still running), like it needs a rest, and kicks back on. No error messages. Some boat neighbors suggested that I should clean the lines with barnacle buster stating that maybe there is poor flow and the compressor is overheating and shutting down a bit until it cools and starts again.
I do not leave the AC on all the time, and use only when at the boat from time to time.
Question 1:Anyone have similar problems? thoughts?
I have had this boat for two years+ in Florida and I have not cleaned the AC lines in any way. I do not know the history of cleanings prior to that.
Question 2: has any one used barnacle buster? The suggestion (supported by some Youtube videos) suggest closing seacock, blowing out the water with exhaust side of vaccum cleaner, hooking up a garden hose with funnel to raw water intake (prior to the pump), and filling with Barnacle Buster until you see the barnacle buster start coming out of boat, letting it sit for 4-6 hours, then flush with freshwatar. Reattach hoses, open seacock and turn on AC and off to races.
I am little leary about setting barnacle buster in the pump, But the guys at the dock say they do it all the time.
NormSail 350 - 2003 Hull 41 (if I recall correctly).
