Long distance solo racing thoughts
Posted: Tue Jul 05, 2022 8:23 am
Hello all. Can't thank everyone enough for the outstanding input on this forum. Recently completed a race across Lake MI w/100+ other boats. Had a blast and although I did not place very well (last in shorthanded), if I had entered the "PHRF crewed class" I would have actually been 2nd in class in Queens Cup against some go-fast racing J boats and Tartans. Finished 81/89 overall. Found (as others have) that, though the C350 will not set many speed records, our boat can be fairly competitive racing if lightened up (removed heavier cruising gear, eg outboard on stern mount and zodiac packed in starboard locker, and emptied the forward water tank and left w/50% fuel level). Never did use code zero due to wind direction and averaged nearly 6.4kts for first 4 hours of the 13:40 journey.. top speed was 7.5. Highest I've ever seen on Ave Maria when surfing downhill in 15-20kts was 8.6kts (no current) SOG.
If anyone has any tips or suggestions for future long distance solo races on the C350, I'd be very grateful (other than to bring beer
). I have considered adding a lee cloth setup for starboard main cabin setee but haven't pulled the trigger. Based on wx forecast I may throw the zodiac in locker for next 4 day race and lash to foredeck if conditions dictate.
Also if anyone has replaced the autopilot with the Raymarine Evolution series, can you give me any feedback? Current Autopilot is the one that came with boat (Raymarine) in 2004 and tends to wander a bit (+/- 15degrees) when winds blow more than 10kts, on virtually all points of sail.
Currently signed up for SuperHook race (Racine, WI to Menominee, MI on GRB and back) on July 16. Praying for good wx and winds.
John McFadden
Ave Maria
#212 2004
ps Atttached is a pix of all safety gear aboard that I use for solo races. I consider each item essential (especially at night). I rarely have to leave cockpit for foredeck. Not pictured: backup waterproof VHF, SPOT Gps tracker, and Ocean Signal PLB1 rescueME strapped to lifejacket
John McFadden
Ave Maria
#212 2004
