Leaking ceiling
Posted: Sat Jun 04, 2022 8:10 am
I have a leak coming in around a plug in the ceiling. Fortunately it's right over the sink. When I removed the plug i could not determine the origin. I did see a bolt, with no nut, that appears to be part of the traveler securement to the deck.
I am in the Bahamas still so this tropical storm is testing all the seals.
Anyone else have this issue.? Also should there be a nut on the thru-deck bolt?
Thanks in advance.
Thanks in advance.
