Battery Test Switch
Posted: Sun May 15, 2022 2:51 pm
by mattmcd62
The Battery Test Rocker switch on my electric panel works intermittently. I have replaced the rocker switch twice, but I still have the same problem. Sometimes when I press it to either 1 or 2 it works and sometimes not. The wires seem to be snugly connected to the switch. Any suggestions on where I should check?
Thank you
Matt
Three Sheets #111
City Island NY & Punta Gorda Fl
Re: Battery Test Switch
Posted: Sun May 15, 2022 5:38 pm
by ElizabethG
Hi Matt,
Mine does the same thing.
However, if I wiggle the switch a little, it does read.
Mine is definitely with the switch which I have never replaced.
Where did you find a replacement switch?
Atlanta / Charleston
2004, #193
Posted: Sun May 15, 2022 9:02 pm
by mattmcd62
Hi Bill,
Thank you for the reply. I will try your suggestion.
I purchased the switch from Catalina Direct. Here is the link to the switch I purchased. Very easy to replace. 10 minute job.
https://www.catalinadirect.com/shop-by- ... ting-hole/
All the best,
Matt
S/v Three Sheets. #111
Posted: Fri Jun 03, 2022 2:39 am
by D&M
From memory this is wired to the input terminals of the battery selector switch. You could check there, but if neither is working then I would look at the negative battery connector which will almost certainly be common for both.
I am unable to visit my boat to confirm atm as down with Covid and in iso.
Posted: Sat Jun 04, 2022 6:22 am
by mattmcd62
Hi David,
Thank you for the reply. I will take a look at the connections you suggest. I hope you feel better!
all the best,
Matt
Three Sheets #111
City Island, NY
