Head Plumbing problem
Posted: Thu Sep 23, 2021 9:53 pm
On my 350 which is a 2008 model hull 460, the head is plumbed via a Y valve so what one can select the flushing fluid. Either via Raw water in my case salt water or in the other position, fresh water from the forward tank.
I have attached 2 photos. The second picture is the Y valve which is located just below the holding tank. The lower white hose goes to the head inlet pump, (CORRECTION: THE LOWER WHITE HOSE IS THE SALT WATER INTAKE) the upper white hose is the salt water intake (CORRECTION THE UPPER WHITE HOSE GOES TO THE HEAD INLET PUMP) and the smaller hose to the left is the fresh water intake, which connects to the blue pipe (via a T joint that is located under the sole of the V berth Picture 1) that takes fresh water from the forward water tank to the manifold and then to the pump.
Here is the problem:
Everything works fine when I set the Y valve to flush with salt water.
When I set the Y valve to fresh water a trickle of water comes through then stops.
The forward tank is full and the flow to the manifold is normal as I get good flow through the faucets.
I suspect the thinner (fresh water intake) hose may have an internal blockage but I cannot feel or see anything.
Do other 350's have this arrangement?
If so any issues with it?
Trevor Rabie
#460 TREVI
Trevor Rabie
#460 TREVI
