Lifting companionway ladder out of the way
Posted: Wed Aug 11, 2021 7:08 am
Urban legend says this topic has been covered here in the past, but I can not find it. While motor sailing recently, strange noises came from the motor. Sounding like a fan belt issue. Two of us went below to investigate. Capt. Bill said grab the bottom of the companionway steps and pivot them up while I pull off the engine front cover. He said you know you can tie those up to the handhold on the ceiling and never have to stow the ladder.
What a great idea. No moving the 43.5 lb. steps. No leaning the steps on anything. The problem is when you raise them up the top step ends up contacting the fiberglass. Capt. Bill said some sailors have cut off the back part of the top wooden step to get the ladder to raise up further.
The top step has a horizontal gap of about 4 inches before the next lower step. The rest of the steps do not have any horizontal gaps. So I thought if the top step moved forward more it would be more like the other steps.
I removed the top step. It can only be moved forward about a half inch before the metal supports under the steps can be seen peaking out behind the two wings. This to me is the limiting factor. So I moved the center section forward a 1/2 inch. and screwed it back down. Then lined up the two wings with the center section and screwed them into position. Raising the ladder up till it was against the vertical fiberglass wall. I approximated where to cut the wing in a parallel line to the wall, using blue tape. Using a jig saw set at a 20 degree angle, I shaved off about 3/8” of wood. Allowing the steps to raise up higher with out being able to see the metal supports below the wings. Measuring from the cabin sole to the bottom of the steps. Prior to the alterations, it would only raise up 16”. Now I can raise up to 24”.
