Charles 3000 Charger -- Dual Battery Charging
Posted: Tue Aug 10, 2021 4:18 pm
Hello,
On my C-350 Dreams of Blue Hull# 176 I have 2 battery banks (Bank #1 House and Bank #2 Single Group 31 Battery).
On my last trip out I discovered that battery #2 was dead. This was after I forgot to turn the breakers back on from my prior trip. So, I chalked it up to the battery not being charged and maybe it was getting a little weak. I started the engine on Bank 1 and moved my battery switch from 1 to all to 2 and motored out. On my return trip, the engine fired up on Battery #2 and I motored back in (short ride for me about 15-mins).
Upon further investigation I found that my battery charger was charging bank #1 but not bank #2. I pulled the fuse from the battery charger feed and found that the 30AMP fuse was blown. Another tidbit was I purchased Dreams of Blue last year and was following the instructions on the boat that stated that Bank #1 was the Group 31 battery and Bank #2 was the house -- as described above this was backwards. So, for an entire year I've been giving preference to Bank #2 for everything (starting the engine, running my 12V systems at anchor/mooring). Essentially, I've not been utilizing my house batteries (2x4Ds) in Bank #1.
In addition, I also noticed that I was getting repeated bubbling out of my 4D batteries. I'm starting to think that Bank #2 was getting depleted and the Charles 3000 charger was sensing low voltage and going into a full charge cycle and charging Bank #2 but also overcharging Bank #1. So, here lies my question -- is the Charles 3000 designed to charge 2 independent battery banks or is it designed to charge 2 batteries in the same bank with same level of consumption and depletion? This would explain the bubbling on the 4Ds and probably the blown fuse by oversupplying power to Bank #2 from Bank #1 (when it goes into a full charge cycle).
Thoughts are appreciated.
Chris
Chris
