Material in bilge hull spaces
D&M
Post by D&M »
Hi all,
Just wondering if anyone else has a loose fluffy material floating around in their hull compartments (bow and stern). Which sometimes get moved into the bilge area. I can pick it up with my fingers but it dissolves instantly when placed in a bucket of water. I have seen it in the stern compartment as well as in the area where the fwd transducers are. Any clues on what it is and where it is coming from?
Regards,
David
Sea Lanes #281
Cairns, Australi
a
Re: Material in bilge hull spaces
Hi David,
I have a feeling there is a bit in Avalon (hull 150) but I have never paid attention to it as assumed it was just a bit of fibreglass fluff left from manufacturing. Obviously not if it dissolves, so no idea sorry, salt crystals would be the only other likely reason if your boat is very dry internally??
Russ
D&M
Post by D&M »
Thanks Russ,
The boat is very dry except for a now fixed leak at the anchor winch and a very slow drip from the anchor well drain. I was concerned about the material but like you think it was something to do with the manufacturing process.
Regards,
David
Sea Lanes #281
Cairns, Australi
a
